Hi fellow IH enthusiasts.
I have two McCormick IH‘s, a 624 and a 523.
I have some experience with the agriomatic s transmissions as I spent my december holidays repairing the 624 some years ago.
The 523 has an interesting problem: It loses drive when selecting agriomatic range, but only when you are shifting from low range.
It works prefectly fine when in reverse and in high range.
I am suspecting that the control spool which is operated by the range select lever is slightly out of position, only when in low range though.
Any ideas? Is there any way to determine the correct position for this block? From what i can remeber it is only "mounted" by the copper hydraulic tubes that seem to hold it in place.
This is an excellent forum and I look forward to learning more about IH in the future.
FYI, I am in South Africa and the 523 is a MY1969.
Please excuse the poor grammar and if my wording is unclear as I am Afrikaans speaking and as a result I am using a translator.
