956axl front drive problem
veljo1985
5 November 2014
25
popovača
Hello,
My friend recieved new front transmission pump  as i ordered it,and still have problems with front drive.
Electromagnetic valve works fine,he got pressure in system..what else could he see if someone have idea,sticked clutch discs on front drive or...?
Regards,
Velimir
what Do you mean with front transmission pump? The pump in the gearbox? Is the elektrik ok? You can try put 12 V on the magnetic valve on the Left side of the gearbox. maybre a wire is broken and its no power on the valve or to less Power an de valve works not perfekt but it looks good.
You can disassemble de valve and have a look on the control slide maybe its have to big scratch.
It can also be the clutch. In the years lots of dirt rub be in the gearbox sometimes to mutch dirt rub an de clutch can’t work fine.
I hope my english is not to bad ;-)
We found problem,soleonid valve works fine...the sealings in clutch are broken so oil sticks clutch disks...
Hope someone can write part numbers for sealings kit ,i will be happy...
Your english is very good,but u can write on german,i can read it good:)
