case ih 956 transmission probs
956xla
1 Februar 2012
1
hi all first post here i have a 956 4wd here with a problem with the pressure lube warning light,  when the tractor is in 2wd the trans lube warning light will come on after a short time,  when switched to 4wd the light goes off instantly,  i pressure tested the pump it was putting out 18 bar,  would i be right in thinking it maybe a leak or fracture somewhere in the pipework in the trans, the tractor got stuck in 4wd a few months ago i pulled out the lube pump suction filter after there was only a small amount of metal pieces on it,  i have the 4wd propshaft off at the minute and the solenoid electrical connection disconnected the warning light works fine now does its normal thing when the key is turned before starting the engine. sorry for being a bit longwinded thanks for any replies  tom  thanks for the welcome sven hope my post is a bit better now.  thanks for any help
Hey Tom,
first of all, welcome to this platform! Of course you have realized, that this is a german board. So i would like you to restructure your post. In my eyes it seems to be a little bit confusing.
For example place some breaks after each step you have taken to look for the damage. This running text is (for example for me) hard to read.
The second point is, that in Germany the measurement unit "psi" is not the standardized unit, so i would like you to recalculate it into the preasure - unit "bar".
After this little restructuring action, I‘m sure that we (the board) can help you as far as we are able to.
Greetings Sven
"Ich bin der Schlepper aus dem Neusser Land, und hab geschleppt schon allerhand, die größten Pflüge weit und breit, zum Schleppen hab ich immer Zeit."
